Author Topic: aircon cooling coil leaking.. help..!!  (Read 4278 times)
Offline nautyprem
« on: June 16, 2009, 11:45:41 PM »
dear lations, does anyone know a trustable shop to change my air con cooling coil as mine is leaking. just went to TCM to check and 80% shld be aircon cooling coil as i realise air con not as cold as last time. TCM is $1200+.. but i understand outside can get arnd 500+.. anyone experience same prob before or know a trustable workshop do let me know.. thx in advance..
Re: aircon cooling coil leaking.. help..!!
« Reply #1 on: June 17, 2009, 11:26:59 AM »
how you know is leaking ?
taztanmu
« Reply #2 on: June 17, 2009, 11:35:49 AM »
You can try shell svc center , what they do is pump up the gas and tracer to see where is the actual leak. if the coil is leak the spare part + work man ship is around 800+ for original Coil.Alternative you can ask them for recon set.
How old is your car, mine is 4 years old. They said is quite common for our model that we have this problem
Offline Everince
« Reply #3 on: June 17, 2009, 12:17:13 PM »
Those car that is coming to warranty end like in few month time, faster go sent to TCM for checks. They will replace it FOC with regard to aircon matter...dun wait even if there is no problem to your aircon. Go there just voice out your concern and let them get it replace... usually they already know air con tend to have problem when warranty abt to over. For my, I sent in just 1 month b4 warranty over and they replace my entire aircon unit FOC at TCM. Hope this advise do help.. ::)
Offline nautyprem
« Reply #4 on: June 18, 2009, 12:08:19 AM »
thx for the advice bro's.. n ii do agree before warranty expire change it foc.. alot of ma frens recommend to do it jb.. hmmm.. will check it out this sat..
Offline gunner1976
« Reply #5 on: June 19, 2009, 12:59:48 PM »
Hi there,
do u guys send in ur rides to TCM for service regularly? If no, will they entertain the warranty claim on the a/c system?
once i drove into TCM regard a steering coupling issue, the SA sort of "warn" me that next time they wont entertain my claims if i do not service at TCM.
