Author Topic: 40k today at Autosavers  (Read 13221 times)
Re: 40k today at Autosavers
« Reply #20 on: July 23, 2009, 12:40:33 PM »
Does this timing chain= fan belt? I'm confused by all this haha. Mechanic told me fan belt was changed.
« Reply #21 on: July 23, 2009, 12:54:21 PM »
actually, it is a drive belt which links the crankshaft pulley, water pump, alternator and air conditioner compressor
the radiator fan is electric-driven
« Reply #22 on: July 23, 2009, 01:52:01 PM »
just curious hor... does the 'crankshaft pulley, water pump, alternator and air conditioner compressor' need any maintanance huh?? i was under the impression that all rotating parts need lubrication/grease repacking sometime or another...
Offline nzmg
« Reply #23 on: July 23, 2009, 02:02:22 PM »
Hi, i will be due for servicing at autosaver.
my problem is my car have a squeaking sound every morning i start the engine.
but after 15 mins or when engine warm up, the sound is gone.
anyone encounter this problem??
suspect the belt but which belt will likely to give this problem?
thanks
Last time when I had this problem, I went back to TCM and the workshop spent half a day to troubleshoot and adjust for me (FOC).
Just ask Autosaver to rectify it for you, since you are going there for servicing.
Offline dtkl
« Reply #24 on: July 23, 2009, 09:05:32 PM »
going to due for 20000km servicing... which Autosaver is better?  TCM is too Ex liao
« Reply #25 on: July 23, 2009, 11:35:41 PM »
Can try River View Auto  too
http://www.riverviewauto.com.sg/
Offline dtkl
« Reply #26 on: July 23, 2009, 11:54:29 PM »
How much it cost at RV for a 20000km package?
Offline rocket
« Reply #27 on: July 25, 2009, 12:29:19 AM »
yes, i have this problem too, once chg the belt & tighten, squeaking sound gone!! peace of mind :D
what is your milage when you changed the belt?
My car milage is around 40k,  also same  squeak sound after start up, and gone after 10+ minutes..
don't know why, belt also need warm up?
« Reply #28 on: July 25, 2009, 12:35:54 AM »
during 40k servicing.
got this sound long ago... since 20k i think or after i changed LWP. dun bother it as i know is the belt issue till 40 k than replace a new 1.
belt starts to cracks & torn under high temp, it get harden too
« Reply #29 on: March 31, 2011, 11:31:55 AM »
I changed my fan belt at Riverview for $36. Labour charge was $15. Seems pretty reasonable comparing to autosavers.
Call up riverview today, they quoted me $70 with original part from Japan with labor. Your part is original as well?
« Reply #30 on: March 31, 2011, 10:25:53 PM »
timing chain is inside the engine.the belt they refering to is the drive belt ,only one belt that drives all pulleys ;)
Offline jovially
« Reply #31 on: April 01, 2011, 10:28:16 AM »
I called up RV asking about original left side skirting, they not sure what part is that, ask me to drive in and they will help to check outside.
Anyone got any other workshop that can replace original parts from Japan? thanks
