Author Topic: Grr Grr  (Read 11460 times)
Offline pmet
Grr Grr
« on: August 06, 2009, 12:24:58 AM »
I've recently been hearing this GROWLING (Grr Grr Grr Grr...) noise, not sure from the front or back of the car. This only happens at 2nd and 3rd gears at around 2 - 2.2k RPM. The noise becomes louder when I step harder on the accelerator but disappears when the gear shifts down (RPM goes up). I'm not sure where this noise comes from but have a feeling it's from the exhaust.
Offline vortex
Re: Grr Grr
« Reply #1 on: August 06, 2009, 08:16:08 AM »
Yours cvt latio ?
Offline pmet
Re: Grr Grr
« Reply #2 on: August 06, 2009, 10:28:19 PM »
Mine's 4AT -- the Grr Grr sound only happens at 2nd to 3rd gear at RPM 2k to 2.2k
Transmission problem?
Offline alvinloo
Re: Grr Grr
« Reply #3 on: August 06, 2009, 11:43:11 PM »
Does it sound like those taxi grr sound? Maybe engine air filter too dirty?
Offline pmet
Re: Grr Grr
« Reply #4 on: August 07, 2009, 12:06:00 AM »
Sounds like a noisy taxi engine without the vibrations... grrrr grrrrrr
something in between water/bubble and metal sound
a little like the exhaust pipe shaking under the car
Funny thing is that this only happens at 2k - 2.2k rpm (second-third gear) and is muffled when the rpm goes above or below that range. I'm thinking could this be a transmission problem? You know when you drive a manual car, when the speed is insufficient (say 20km/hr) then you put on 2nd gear and step hard on the accelerator, it stresses the gears...
Re: Grr Grr
« Reply #5 on: August 07, 2009, 12:55:33 AM »
Very difficult to diagnose unless we hear the noise.
Suggest you send to Tan Chong to check if car is under warranty.
Offline pmet
Re: Grr Grr
« Reply #6 on: August 07, 2009, 09:26:03 AM »
Scared later bring to TC they say "normal" leh. Anyone else having this prob? Car is around 2yrs old, bought new.
Re: Grr Grr
« Reply #7 on: August 07, 2009, 09:56:04 AM »
Go tan chong, if they say normal, ask them to "demo" that sound on other latio. They sure have some other latio doing servicing there right?
Re: Grr Grr
« Reply #8 on: August 07, 2009, 10:39:19 AM »
If Tan Chong uses other customer's car to demo and gets found out, it will be in breach of the servicing terms and Tan Chong risks legal action taken against them, in extreme cases.
It is advisable for Tan Chong to use their test drive car to demo, if necessary.
Re: Grr Grr
« Reply #9 on: August 07, 2009, 12:06:18 PM »
bro, the SE will start other latio engine for servicing too, nothing wrong to take a look with your SE right? Not that you are going to test drive it.
TCM sure have new Latio and demo latio for test but those may not be the same as other on-the-road latio around the same year as pmet's. TCM will say "new car dun have the sound but drive over a year will have, normal one". That's why you need to take a look at other latio but not those new one.
Re: Grr Grr
« Reply #10 on: August 07, 2009, 02:57:26 PM »
pmet says "This only happens at 2nd and 3rd gears at around 2 - 2.2k RPM" when he is driving, so if Tan Chong ues another customer's car to test, it means they would need to drive it to experience if there's the Grrr sound.
Re: Grr Grr
« Reply #11 on: August 07, 2009, 03:37:25 PM »
have those test platform that can test the car one. small workshop will not have but TCM should have.
Offline pmet
Re: Grr Grr
« Reply #12 on: August 08, 2009, 02:13:49 AM »
Thanks for your inputs guys. I'll bring to TC and see what they say.
Offline nglipthian
Re: Grr Grr
« Reply #13 on: August 17, 2009, 10:48:38 AM »
Hi
Could it be the air in take sound? It will happen if using lower grade of petrol such as 92 UL. Alternately, try to tighten the fan belt. Sometime it help.
Regards
Re: Grr Grr
« Reply #14 on: August 17, 2009, 08:44:19 PM »
Hi
Regards
Never heard of this before. Using lower octane petrol got this sound? Where you heard of this?
Anyway Latio can take anything above 91, so shouldn't be this bah.
Offline pmet
Re: Grr Grr
« Reply #15 on: August 17, 2009, 11:28:44 PM »
I use Shell 95 so fuel shouldn't be a problem. Tried tightening the fan belt with no improvement  :(
