Author Topic: Will Ikey auto lock our door, if we forget to lock and left?  (Read 10506 times)
Offline tweakmax2
« on: December 02, 2009, 11:43:24 PM »
anyone ? ???
Re: Will Ikey auto lock our door, if we forget to lock and left?
« Reply #1 on: December 03, 2009, 12:14:03 AM »
no - the Intelligent Key is not that intelligent
« Reply #2 on: December 03, 2009, 12:38:25 AM »
if u unlock but never open door and leave it, it will lock itself.
Offline treblebass
« Reply #3 on: February 04, 2010, 12:28:13 PM »
on an earlier incident, i left my ikey in the booth without realising it... thinking the ikey is in my pocket. i pushed the key button on the booth and it locked readily.... however, upon waling away, i realised i did not have the ikey in my pocket... i went back to my car and tried to open it by pushing the button but to no avail...finally called tan chong and they said they cannot do anything... in the end, i took a cab to my house to retrieve my spare keys and manually opened it... moral of story - keep your spare keys at home!!!
LaChio
« Reply #4 on: February 04, 2010, 12:43:04 PM »
No, moral of story - keep your spare keys in the other pocket!!! :bleh:
« Reply #5 on: February 04, 2010, 12:47:53 PM »
technically it will not lock in this case if you press the black button on the boot while ur ikey is inside the boot....same case as if ikey is inside car, by pressing black button on oustide door handle, it will beep beep beep and not able to lock....
could your case be something else?
Offline treblebass
« Reply #6 on: February 04, 2010, 01:06:28 PM »
yes, technically the car cannot be locked when the ikey is inside the car...but it happended on this rare incident where i left my ikey in the boot... thats why i called tan chong to enquire but they couldnt assist me and advise me to use my spare key to open it... funny.....
« Reply #7 on: February 04, 2010, 02:52:50 PM »
can you re-simulate again? cos i suspect ur ikey might be very near to boot edge...so the sensor might have detect as outside rather than inside...
« Reply #8 on: February 04, 2010, 02:55:12 PM »
You can use a screw to open up your external signal light casing or rear lamps and hide your spare key inside and screw back the light casing. No one will know. That's what I do.
« Reply #9 on: February 04, 2010, 03:27:27 PM »
hhmmmm....now we all know....
« Reply #10 on: February 04, 2010, 06:55:27 PM »
RFOLMAO.  :thumbsup: :scared: :fighting2: :fighting: :boxing: :hammer: :censored: :blush: :eek:
can we all claim you if we start to see our lights being screwed around with?
« Reply #11 on: February 04, 2010, 06:57:43 PM »
BTW if someone were to rear end you good luck to your spare key too.
having your ikey securely stored in a home environment is still a wiser choice
« Reply #12 on: February 04, 2010, 07:03:29 PM »
anyone ? ???
here is what I know of
1) If you stopped your engine, get out of the car and do nothing, the Car will not lock
2) if you unlock your car from a locked state, and do nothing, it will auto lock
3) if you unlock your car from a locked state, and start opening any door or bonnet, it WILL NOT auto lock
« Reply #13 on: February 04, 2010, 09:45:48 PM »
yes that is correct
Offline hwlee
  • Honda
« Reply #14 on: February 04, 2010, 10:24:48 PM »
It do happened to me...while i left the ikey inside the car..then i locked the car by pushing the black button on the car's door... luckily i am at home that time..i just go and take my spare key and open the car door. one things can sure, our ikey system is secure enough. :D
If any bro/sis wanna to try this..just keep your car windows open..then put your ikey inside the car...and then press the lock button on the car door.  :D
No, no more to worry that my door won't locked. It lock automatically after 1-2 mins of idle.
« Reply #15 on: February 05, 2010, 01:03:16 AM »
To set the record straight, if your i key is inside your car or boot, your doors will NEVER lock.
If it still locks, there is a malfunction.
« Reply #16 on: February 05, 2010, 07:41:28 AM »
i second that. Cos i have numerous occassions left my ikey in the car after washing & when tried to lock after that, it only goes beep beep beep & no locking.
« Reply #17 on: February 05, 2010, 11:09:04 AM »
ur ikey sensor is located juz behind the rear view mirror, so i tink either ur ikey batt is weak or either ur sensor wanna up lorry oledi.. not possible dat u can lock ur car even if u hide ikey inside spare tyre compartment.
Offline hwlee
  • Honda
« Reply #18 on: February 05, 2010, 11:16:37 AM »
Try few times (put your ikey below the Armest or driver's side door compartment), i sure sometime i will SUPRISE you. ;)
Offline nakshire
  • I'm a cute boy ok!
« Reply #19 on: February 05, 2010, 11:21:03 AM »
i need ur license plate number... muahaha
