Author Topic: Air flow intake alternate from fresh air intake and recirculation by itself  (Read 36546 times)
Offline WONWON
  • Car Color: white
Recently my Nissan's air con has issue, the air flow intake will alternate between fresh air intake and recirculation even though I have it set at  recirculation. the problem with this of course is that smell/dust from the outside will flow in and temperature will increase due to hot air intake from outside.
See this video.
http://www.youtube.c...h?v=lf1XX9g8ktg
Anyone had this problem before, what was the issue? And what was the remedy and cost?
My ride is 2.0, the buttons are a bit different, you have the 3 buttons Clean/ Fresh Air Inatke/Recirculation.
From what I read, most likely it's the cooling coil sensor or the compressor or A/C control PCB, but I'm sure most workshop will
just say compressor, that'll cost a bomb to replace. So I'm asking around to see if anyone has encountered
this problem before. I saw a few posting on similar problem, but no mention of the  real cause, solution and cost.
Offline JT
  • Car Color: Blue
Hi, Did you manage to find a solution ? I have the same problem with my Sylphy.
Offline rongshu
https://www.sgnissan.com/forum/index.php/topic,13645.msg205304.html#msg205304
could be the compressor.
You can go to either Kelvin or Yee Sing (Technic Motorcare) to check. Their contacts can be found in the forum under Premium Merchants .
« Last Edit: August 28, 2018, 10:09:49 AM by rongshu »
